Hangkai 6 hp water pump outlet
Texas3Ted
I have a Hangkai 6 hp two stroke outboard. I am not getting a water pump exit stream. For the life of me I cannot find the outlet hole on the exterior of the motor or the internal hose that should provide this flow. Any help would be appreciated.
Texas3Ted
Thanks. Just now found the outlet hole. It is actually a hole in the middle of a bolt. Not clogged so now I'm working on finding the impeller part # so I can replace it. Thanks again.
matt167
which model? The 6hp 2 stroke should be a cheap copy of an older Yamaha
