Gunwale support replacement - Starcraft Holiday 18 i/o
sprintst
My gunwale supports that I pulled off have a couple of bad spots. They are also over 9' long.
Just checking to see if I should laminate 2 - sheets of 1/4 inch plywood with overlapping joints to make the thickness and the length. I was thinking of making an epoxy sandwich with the sheets rather than trying to find 10' plywood.
When it's done I could also fiberglass them for waterproofing, etc.
CheapboatKev
Re: Gunwale support replacement - Starcraft Holiday 18 i/o
you mean these side panels??
sprintst
Exactly... Did you reuse or rebuild.
