Guestimate the hours!
oops!
19 footer, i/o (out) closed bow. solid fiberglass.
from start to finish
deck off
floor, stringers, foam, transom,
one man, inexperienced, some times two, mostly one.
approx how many hours?
oops
Re: Guestimate the hours!
Ayuh,.........
Best Case......... 100/200hrs..........
Worst Case,...... A lifetime.................:D
Chinewalker
My boat is similar - 18-foot, fiberglass, outboard, closed bow. Completely gutted and replaced every stick of wood. Probably upwards of 100 hours actual work time, including a rebuild of the motor. Lots of nice little 1/2-hour and 1-hour jobs to do in the evenings, so it breaks up nicely.
- Scott
oops!
i was thinking a hundred hours for hull/stringers/transom.
im just about to start this weekend. and wanted to know if im being realistic.
thanks. anyone else?
oops
tashasdaddy
keep the projects small enough, that you can see the progress, or you may get discouraged.
