Grr. Black smoke from the exhaust
Angrywasp
Well after my third attempt to take the boat out and having it die (again) after starting to drive it to the dock from the trailer I took the boat home. It had fouled the plugs again (same thing it did the last 2 times). I leaned the carb out a half turn and had it running on the muffs in the drive for about 10 mins so it was up to temp (right in the middle of the green band) and running fine. Then it started sending black smoke out the exhaust so I immediately shut it down. I had some issues with compression a couple of weeks ago but got the boat running and it didn't seem to affect the way the motor ran once I replaced the ignition module. I was leaning towards the headgasket (and am again) when the ignition module issue popped up since I had low compression on 2 cylinders. I'll have to investigate more tomorrow but I'm open to suggestions right now. Any ideas? I'm beginning to think my boat is afraid of the water.
Don S
Re: Grr. Black smoke from the exhaust
Is the choke open when the engine is warm? It better be.
79Glastron
Black smoke is rich fuel mixture. I doubt your idle mix screws will cause your problem. I would be looking at sticking float, damaged needle and seat, and of course, stuck choke. Do you have clean fuel? Whats your fuel filter look like? Might be time to rebuild the carb. I could see a very, very dirty flame arrestor causing you to run rich also, but unlikely. A look down the carb throat when its acting up will tell the story.
Angrywasp
I'll check both tomorrow. The boat will rev fine (out of gear) in the water. It just shuts down when the motor has a load on it.
6meter
You mentioned compression issues. They don't come and go. How low is the compression? You are running very rich. Might be fuel in the oil, washing the cyl walls or blow by vapor going in the carb through the vent hose. Along with what others have mentioned.
Have you pulled the dip stick and done a sniff test for presense of fuel? Is the oil level over full? Both signs that you have a serious carb problem. Such as needle and seat not sealing. Lots of black smoke says "waaaaayyyy" rich. With a warm engine the choke plate should be standing verically in the carb bore. If not, start there.
Ayuh,... I agree, at 1st glance, the Carb is probably Boogered up, Big Time....
But,...
A ruptured mechanical fuelpump diaphram could also be the culprit...
Does the semi-clear tube between the fuelpump, 'n carb have any fluid in it,..??
Angrywasp
Okay. Here's what I've found so far. The carb settings were way off so I checked everything against the manual and set it all to factory spec. It started right up after with no problems and no smoke. I let it warm up good and started dialing in the idle. I noticed a change in the engine tone and checked the gages. The temp gauge was almost to the top of the green band so I shut it down. Well I pulled the impeller housing off and it was completely dry (and impeller toasted). Turns out my muffs are bad (could squeeze them with the water on and impeller out and water would come out the housing but wouldn't if I wasn't squeezing them). After about half an hour I decided to do a compression test and cylinders 1,2,3 were 160-175 psi while 4 was 90. The previous compression test was with the motor cold and I got 100, 50, 110, and 90. No smell of gas in the oil (although there was some water on the inside of the valve cover.) and there isn't any gas flowing through the bellows rupture hose from the fuel pump. The oil is milky looking and for some reason my oil pressure seems to be fluctuating. Sigh. Any ideas besides sinking it in the ocean while it's on fire?
choochooharley
Well it sounds like you have bad compression in #4 and with the mily oil that means water is in the oil could be a bad head gasket causing the low compression and the water....as far as the black smoke that is probably a seperate issue with the carb....my suspisons are float needs adjusting or you need to rebuild it or a stuck float.....
Fireman431
You're biggest issue appears to be a head gasket. The milky oil is your primary concern. That would also account for your compression numbers being way off and the temp going up. They can be different, but really shouldn't vary more than 5-10%.
Once you fix that, take another look at the carb and either get it fixed correctly or replaced.
GLENN M
if muffs arnt working howd you get water in engine? your cyl pressure numbers are all over to one test to low the next,what kind of tester the one you hold or one you screw in? black smoke is to much fuel.air flowing throw venturies causes pressure drop which draws in fuel,so no air no fuel
Angrywasp
My gages monitor oil temp and pressure. I don't have one for water temp. It was sheer inattentiveness on my part to not notice there wasn't water coming out of the prop in addition to what was spraying out from my muffs. I use a screw in style compression tester and compression of a motor changes depending on it's temperature. Plus if the head gasket is bad it would change also. The black smoke issue is solved (even though the plugs are still pretty black) but fine tuning will have to wait on the impeller, probably the head gasket, and a trip on the water.
dubs283
huh??
are you sure the temp guage is for oil temp??
it is probably water temp unless you or somebody else changed it at some point
i can't see any engine manufacturer installing an oil temp guage and no water temp guage
Angrywasp
huh??
Yeah you're right. The symbol on the gage is almost exactly the same as the oil symbol for cars. Slowly learning to pay closer attention to everything.
JetBote
Your plugs will not clean themselves. They will remain black.
Angrywasp
Actually if you have the engine up to temperature, correct air/fuel mixture (which I still don't but it's better than it was), and the plugs aren't fouled to the point where they won't fire (which they were) they will clean themselves becuase they will burn the carbon deposits off. A butane torch and a pair of pliers will net you the same result. I've also used a toothbrush and gasoline to remove some build up too.
JetBote
If you want to get a correct plug reading, you cannot use old plugs. Sure, you can clean them to get a spark, but that's the only benefit. A correct engine temp and mixture will NOT clean plugs. The carbon build up can continue to build up and prematurely detonate the fuel mixture.
ChampionShip
Time for a complete carb rebuild- start there to eliminate variables. Alot of boats will run great on the muffs and then fall on their faces with a little backpressure being in the water......let's just say I have a newly rebuilt carb:rolleyes:
Angrywasp
Seems NGK thinks otherwise. Appreciate the help though.
http://www.ngksparkplugs.com/tech_support/spark_plugs/p2.asp
Just because I'm new to boats doesn't mean I don't know what I'm talking about.
I'll probably be pulling the carb this week then while waiting on other parts.
JetBote
Oh, the guy that doesn't know what black exhaust means, nor knows the difference between an oil and engine temp gauge is versed in spark plugs? Ok.
