Dabbler_E
Thread starter- Joined
- Apr 20, 2009
- 338
Hi All,
I know that wiring should not be grounded to an aluminum hull -- there should be direct wire connections back to the negative pole of the battery.
But, if I use a ground bus bar wired to the battery, does that bar need to be electrically insulated from the hull, or is it OK to simply attach it to the hull?
Thanks,
Thanks,
