grey oil leak
944own
I took my boat out today i recently purchased it has a 3.0 omc cobra engine it seemed to run great all day no problems at all but when i took it out of the water i noticed this grey oil leaking heavily from it looks like a boot or something that comes out of the boat and goes to the lower unit i am sorry i cant explain it better but does anyone know what this could be the trim still goes up and down and i just dont know enough about it to know what it might be please help
Re: grey oil leak
Ayuh,....
Your Outdrive has a Serious Leak,.....
If you can't explain it, I'm betting you can't Fix it either,....
I suggest you find a Marine Tech who knows his way around an OMC,+ contract him to Fix it.....
Don S
Re: grey oil leak
The ujoint bellows probably has a hole in it, the water gets in the drive, and turns milky gray. Then sense the drive is overfilled, the heat of operation forces it back out of the drive and into the bellows.
If it's like other "Gray" gear lube I have seen, it's thick and almost impossible to wash off of parts. The drive will have to be dissassembled and cleaned, new bellows, ujoints, gimbal bearing, and probaly the input shaft seal and yoke if rusty and grooved.
Deanrw3
Re: grey oil leak
sounds like fluid from your trim pump. Mine was a gray color, however it could be a lot of things. Trim the drive up and down and listen for a bubbling or a "ttisss" If you hear this your hose is prob. broken. Also your trim will stop going up and down soon as you loss enough oil. Try checking the amount of oil in the trim pump and see if the level has dropped.
This is the only fluid i can think of that is gray and has that much fluid to leak.
GL
Dean
Re: grey oil leak
Ayuh,...... It shouldn't be.......Sounds Dirty,+ Wet.......
a70eliminator
Re: grey oil leak
Use the dipstick to check the oil level in the drive. The tube your seeing is probably the exhaust bellows, it looks like round accordian about 3" diameter. The exhaust emitts through this tube, could it be just his engine is burning a little oil and it's accumilating in the exhaust bellows?
sea wolf
Re: grey oil leak
GL
Dean
If it was trim fluid it wouldn't be leaking from the bellows. Run it off muffs in your yard if you can to try try & pinpoint the leak. But, I think Don S. is right on the money with his advice. If there's water in the u-joint bellows your looking at some steep repair bills. Who knows how long it was run that way before you bought it. Sorry.
