GPS Transducers
wgl333
I have a Standard Horizons GPS unit and my boat has a 2 year old Hummingbird dual beam transducer (83khz/200khz)....are the compatible?
mphy98
Re: GPS Transducers
I would doubt it, as far as I have seen every make is different so far. Call Standard horizens to be sure.
dingbat
Re: GPS Transducers
A transducer is a transducer. As long as the frequency is the same it will "technically" work.
The difference is in the connectors and the way the connector is wired to the transducer. Unless you?re willing to cut the connector off the existing transducer and soldering the new connector back on, making any wiring changes in the process, I?d install the new transducer.
