GPS issues on a 2359 HT
marmac
I'm in the middle of installing a Lowrance HDS - 8 On my 2359 and it seems that it can't get a signal on the dash. It would appear that the overhead console is interfering with the satellite signals.
Has anyone else had to deal with this problem? Any suggestions???????
Monterey10
Re: GPS issues on a 2359 HT
This is why people buy units with remote mounted antennas. Only the open hull boats can manage with the internal antennas.
JohnNJ
I know my Garmin 546 comes with a built-in antenna, but I also have the option to add a remote antenna to it.
John
slowolf
If it's a Gen2 HDS 8, you should be able to attach an LGC-4000 external antenna to it. Mount it on your hard top. It will give you a better refresh rate and signal than the internal antenna too. Running the cable connection will be a pain but the end result is worth it. Check with Lowrance to make sure the 4000 will work with your unit. LGC-4000 - LOWRANCE | Marine Electronics
marmac
I went in and bucked up for a LGC 4000 and network kit, nearly 1/2 a boat unit but it worked like a charm. Too bad it wasn't included when you consider the price of the unit....I just set the receiver on the dash and it was gold.
But as I was cruising it would not hold the bottom after I got going with much speed at all. It did for a while and then would drop out. My old unit would register the bottom while on step till about 500 ft.
It has a 50/200 transducer. Any suggestions?
Thanks for any and all input.
slowolf
If it's a transom mount transducer, you may try adjusting the tilt. The transmitting surface of the transducer should be parallel to the surface of the water. Here's a pic of the way mine is set...
attachment.php
