GPI Gaycraft boat question
JimAllen
I have a boat manufactured by GPI in Wisconsin. The tags are off and I don't know what the max. Hp. is. The boat is fiberglass and 15ft long. Does anyone have any info on this boat? It was manufactured in the mid to late 70's in Schofield WI. Thanks for any help!
bekosh
Re: GPI Gaycraft boat question
My first boat was a little 12ft Gaycraft. :) Caught a lot of fish out of her before moving up to bigger & better.
To answer your question, there isn't much info out there on the Gaycraft's. Your best bet is to use the same formula that the Coast Guard uses.
Here is a link to the DOT regs covering boat capacities.
http://edocket.access.gpo.gov/cfr_2002/julqtr/pdf/33cfr183.43.pdf
Basically, you multiply the length in feet by the transom width in feet. Then look up the factor in the attached chart.
If the factor is over 52.5 and the boat has remote steering and at least 20" transom height then you multiply it by 2 and subtract 90 to get the rated HP.
(length x transom width)=factor
If less than 52.5 see attached chart.
If over 52.5 and the boat has remote steering and at least 20" transom height:
(factor x 2)-90=HP rating.
If over 52.5 and the boat does not have remote steering or at least 20" transom height:
For flat bottom/hard chine: (.5 x factor)-15=HP rating
For other style boats: (.8 x factor)-25=HP rating
For your boat I'll take a SWAG at it.
Assuming remote steering & a 20" transom.
15ft Length x 4.5ft beam=67.5 factor
(67.5 x 2)-90= 45hp
Without remote steering.
(67.5 x .8)-25= 29hp rounded to nearest 5= 30hp
marlboro180
Hey Bekosh- Good info.
Jim- Mine is a 14 foot Gaycraft, the guy I bought it from had a 10 hp on it and he was happy with it for puttering on a river.
Heavy, rugged hull will take a beating.
I looked at mine just this morning and and it does not have a plate on it, nor any signs of ever having one. Just a HIN.
For some history-
http://www.gpicomposites.com/Unlimi...essionid=f0305010ea21b94c0fe944263b64354e7d12
bekosh
marlboro180 that looks a lot like mine old one. I had a 1963 5.5hp Evinrude on it. Enough to putt around with but not enough to get on plane.
If JimAllen's is the same style, I'll change my Hp guesstimate to about 25hp max. Narrow beam and a flat bottom.
Home Cookin'
with a name like that, I bet few of them have the hull plates and side emblems
