got float?
skipknot6
I have an old aluminum jon boat. it is a 14 foot boat but is very narrow. for a big guy like me it might as well be a canoe. It is rated for 460 pounds total weight (gear motor and persons). on a typical trip I would say it has about 600 pounds in it. I was wondering if there are any ways to add float to my boat. any help would be greatly appreciated.
Dhadley
Re: got float?
I would think the best way would be to put your boat inside one of the newer wider models. And perhaps treat yourself to a 16'.<br /><br />Seriously, if you even think its overloaded, it probably is.
ZmOz
Re: got float?
No, there really isn't anything you can do to add floatation.
Bass Runner
Re: got float?
I think you better get you a bigger boat yours is way overloaded, you are asking to take a swim in that narrow draft 14' :eek: , I would look for a used 16' wide beam they are more stable you will be a lot happier not to mention safer, most drowndings are from small overloaded boats.
JasonJ
Re: got float?
There is no way to increase bouyancy beyond the hulls ability to displace water other than buying a bigger boat, which I highly recommend. Adding foam to the interior only helps to prevent the boat from sinking, it does not increase its ability to carry a load.
