joshvette001
Thread starter- Joined
- May 22, 2011
- 22
Hey Guy's... Long time lurker first time to sign up and post. I admire some of the great work alot of you have done on your boats and some of the restorations you guy's have done they are amazing. I am 19 and I inherited this boat from my grandpa when he passed away... I have alot of memories on it with him and he loved the boat... That being said I wanted to get some more experienced advice before I go ripping the deck apart. If you take a look at the attached pictures the first one is the hole that is in the corner of the deck... this prompted me to pull off the bench of chairs to take a look under it... IT appears that water is pooled there with dirt. You can see that in the pictures also... My first question is obviously the whole deck should be replaced... When your replacing a deck do you fiberglass over it? What I a seeing is a thin layer of glass that is soaking wet and just pealing off the wood... I a betting there is water pooled underneath here and I want to make sure that I do this properlly.. I am not looking for the cheap way out... I want some advice, first off what is the best way to tear this out? Does this deck go under the whole top portion of the fiberglass in this 87 Espire Cajun? Or does it go flush with it? It appears it goes a tiny bit under it from when I was digging and pushing... Its obvious it has the blown in foam type insulation that will need to be replaced with either pour in foam or the same equivalent... I just want to see where you guy's would start with this boat and what you would do first? Obviously tear the deck out but question is do I peal the Fiberglass layer off first? .... Its a very small shapped inside area and so I want to make sure I dont **** anything up... I am not retarded and I have plenty of handyman skills just dont know a boat as well as I would like to yet.
I look forward to any replies or advice on what you see in these pictures etc or if you need me to take more detailed photos... Thank you in advance for your time and kindness.
