Josh Boram
Thread starter- Joined
- Jun 5, 2017
- 12
I have a 1977 glastron hp 154 the transom is so rotted the motor is about to fall off how do I replace this I really don't want to pull the whole cap off if I lift the door to the bilge area I can see some of the rotted wood and some fiberglass does the wood go between that fiberglass and the fiberglass of the outer hull do I need to cut the outside fiberglass on the outside underneath the motor mount off and replace the wood this way then re epoxy and seal it back up
