Hello again, my rebuild has been delayed due to rain, alot of it. The sun is shining and the forecast is good for a few days so I'm going to get back at it. I am halfway through the tear out of the floor and I got the outboard off the transom on a stand so I have a couple more questions. Firstly, is there a proper order for doing things when restoring a boat? I ask because as I tore out the floor by the transom it occurred to me that maybe I should get the transom finished before putting the new floor down, so should one be done before the other? Also I have taken off all the cleats and lights and everything and a couple of the videos I've watched showed someone separating the deck from the hull, the deck being the part of the boat the windshield mounts to, and the hull everything below that. There was a piece of rubber going around the outside of the boat and when that is pulled off it definitely looks like 2 separate components so do I need to separate the two? Next with regard to the transom, after I removed the outboard it became very apparent that the transom was rotted and needs replacing. After watching some videos about transom replacement I'm a little confused about the existing fiberglass.if I was to remove the rotted wood standing on the inside of the boat I could just cut away the glass on the inside of the transom, remove the rot, and then cut in a new transom that would fit against the outside fiberglass and then re resin and fiberglass over the existing shell. Is that what I'm supposed to do? A couple of the videos looked like that was what was being done, in others it looked like there was a 4" tab left from the original glass that was utilized, I'm a little confused about that, and lastly, should I install something up the inside of the hull to screw the new transom to? It looked like the people in the video were screwing the transom to something but there is nothing there in my boat to accomplish that. Thank you for any advice/suggestions
