d_saum
- Jul 3, 2007
- 80
Hey all, It's been a LONG time since I've posted anything, but I've been reading quite a bit. You guys are a wealth of knowledge and I want to thank you for sharing!
Ok.. now onto the fun stuff. I was recently given a boat by a girl I am seeing, and she knows nothing about it. Zero.. so, all I really have is a name. No title, no specs, etc... It's a McDaniel Mark I bowrider. Probably about 15 feet, with a 70hp Evinrude on the back. The motor supposedly runs good, and I had it running for a few seconds last night. The battery is now needing a jump, and I'm going to pull the plugs and clean them. The transom is pretty weak, and the floor in the boat is garbage (they put planks down there over angle iron, running perpendicular over the stringers). What I'd REALLY like to do is see if there is some ridiculously cheap way to brace the transom so I can get out on the lakes here just to go fishing. I've been searching the forums for transom repair, and there is a TON of great info, but Im not sure if I want to really tear into it completely as I may not keep the boat for very long. Seacast is pricey, and I know I could go cheaper with plywood, but I realllllllyyyyyy don't want to pull the cap off if I can get away with it.
What I'd really like to do is get it running right, use it for the season (on the cheap as Im not employed) and then when I can, either go all out and fix everything right, or take the engine off and put it on something else like a pontoon boat or something.
Also, how does one go about getting a title for a boat and trailer if it's given to you? I have a bill of sale, but I'm not sure that'll help as the boat and trailer were never registered in the girls name.
If this was your boat, and you weren't sure if you were going to keep it, what would you do? Options? Ideas? Thanks so much!
Pics below (if I can get it to work)
