I have a 2006 Bayiner 185. 3.0l
I was running the boat planed about about two thirds throttle. The engine race or revved a bit seemed like I may have hit something in the water. I shut her down immediately, opened the hood, there was a little smoke. She was a bit hot so I let the boat set for a minute and she fired back up but did not go in gear when I shifted. No forward or reverse. Got a little more smoke and smelt like something burning. Got her towed in.
Removed out drive and opened the top thinking the upper unit may have burnt up. Drive oil full and clean. Drained oil down and the gears looked ok.
If there was a gimble bearing failure would it prevent the drive from shifting into gear?
Can the outdrive fail on the lower end and cause this non shifting issue?
The gimble bearing has had a roar to it and sounded like it was bad, never had one go out so I do not know what problems occur when the bearing fails.
Thanks in advance for your replies.
Gallen47
Gallen47
