Gimbal housing removal
Btj
CAN THE GIMBAL HOUSING BE REMOVED WITHOUT REMOVING THE ENGINE? (alpha 1 generation 2 by the way. 1996)
Thank you in advance
Bt Doctur
Re: Gimbal housing removal
remove the drive to access the gimbal housing,
( thats where the drive bolts on.),
the transom housing needs the engine and inner housing removed to remove the outer housing.
achris
More fish than mountain goat
Simple answer to a simple question.... No... The engine rests on the inner transom plate, which is bolted to the gimbal housing... Also to access the nuts holding the inner transom plate to the gimbal housing you MUST remove the engine... If you need to replace the gimbal housing, pulling the engine is no big deal....
Chris......
