WallDiver7
Thread starter- Joined
- Jul 31, 2007
- 18
Here's the poop:
Boat: 1999 1850LS Bayliner Capri, 4.3L V6, Mercruiser sterndrive (gen. II)
Problem:
1. "Something" growls/vibrates when I turn ONE direction while around 35mph. At 50mph, the growl/vibration isn't there.... or I can't hear it. At the 1/2 throttle setting, I have noticed that when I turn the boat the direction that the growling starts, the boat's speed is scrubbed back quite a bit.
2. When the drain plug is pulled at the end of the day, I get no more than 1/2 cup of water. ( as long as we haven't been getting in and out of it into the lake... skiers, divers, swimmers.... etc.)
**I am assuming that since the boat takes on so little water that all the bellows are water tight. Yes?
Questions:
1. Is this gimbal bearing failing?
2. Could this noise just be that the engine is now out of alignment? (This growling noise has very slowly grown louder over the past 4 years. The first couple of years the noise was just intermittent.)
AS soon as the season is over, I plan to tear the sterndrive down and have a look. Any help, suggestions you might have would be greatly appreciated!
Thanks!
WallDiver7
Problem:
Questions:
Thanks!
WallDiver7
