Getting there with my 85!
Craig cK
Ok...well swapped over the power packs and found a loose wire! :) Wahoo! Bright spark on all cylinders now. Also changed the bendix - so all is good!<br /><br />However, She wont run at slow speeds - requiring a dab of choke every so often to keep her running. Give her a handful to open up and it tries to die - a dap of choke and va voom!<br /><br />Mixture I pressume? I assume that giving choke saving the day is an indication that its running lean?<br /><br />Do I just turn every carb adjuster the same amount?<br /><br />As always thanks ever so much for all the help!
JB
Re: Getting there with my 85!
What make and model are you talking about, Craig?
Craig cK
She's a Force 85...just been out and turned the mixture screws out 1.5 turns....running sooooo much sweeter! Going for sea trials in a bit, but still unsure whether I should be tuning one at a time or all the same?<br /><br />Thanks! :)
