jdstephwacotx
- Aug 16, 2004
- 53
Once a motor idles....if you continue to pump the bulb (assuming the bulb and lines are in good working order) should the motor flood and die?<br /><br />I'm trying to think of ways to trouble shoot everything between the tank and the carbs and I have no experience.<br /><br />Other suggestions welcome.<br /><br />Also, when the cover and wrap is off and I can see into the tops of the 2 carbs (inline 4 outboard) should I see fuel spraying into the carbs when I pump the bulb (motor off now)? I definitely should if I rock the throttle between forward and neutral right?
