Gonefishing85
Thread starter- Joined
- Jun 25, 2016
- 90
Gelcoat paste would be the way to go. Not rocket science, but you may want to get the color match (Spectrum Gelcoat Colors), or a color matching 'kit', which Evercoat has.
Since it is a double-curve surface, you may need to do a bit of sanding to shape and fair it with the surrounding areas. Get 220, 400, 600, 800, 1000, 1500, 2000 grit wet/dry sand papers to make it look perfect.
Antifouling paint will cover it, or do you not keep it in the water?
I would patch it with gel, then get a keel guard to keep you from bouncing the boat off the trailer
