Re: gelcoat refinish?
What I use is Duraglass,it is made by Bondo.Make a golfball size on cardboard,stir it up real good first with a paint stick,so all the oils go back down through it,and use maybe a half inch of the white hardner that comes in a tube.You have to move quick,well here in Arizona you do,and make sure you get a new spreader,just a 3" er.Don't stir the stuff together with hardner instead use the spreader and mix it like pie dough,spreading it in,over turning the whole glob until all the hardner is mixed thoroughly,then use small amounts on the spreader and wipe it with the gouge very tightly against the boat,you only want to fill in the gouge,you don't want a big glob of stuff on there that you have to sand for 3 days,understand?I'm a bodyman,I use the stuff everyday.Just try a little tiny bit until you get what you have to do.PM me if you have questions,I am on here a lot.Make sure you stir the can first,that is what Imeant by the oils.Make sure you have a rag there so that you can clean your spreader when you are done,before it gets hard.
