Re: Gelcoat Expectations
ondarvr is right.
While gelcoat is more forgiving in the prep work, it is a beast to get a nice finish. On flat surfaces its not that bad because you can use a DA a foam interface pad and sand it thru 1000 grit, but curves will have to be hand blocked...which sucks.
If you are good at spraying paint you can away with little to ZERO orange peel.
I've haven't tried this product called Duratec high gloss additive for gelcoat. You are supposed to be able to thin the gelcoat with the Duratec and have very little peel. Ondarvr have you heard or experimented with this stuff.
ondarvr is right.
