burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
Hoping I can get some info and advice. This weekend I was removing some vinyl decals from the hull of our boat using a heat gun and Rapid Remover. I work in the sign industry so I have some experience with application and removal of vinyl products. The picture below is from the "S" in STARCRAFT. I have been able to remove all the other letters, a logo and some striping without issue. As I was removing the S, I noticed that on the adhesive side of the vinyl was green. And now I have a spot where it looks like a clear coat or gel coat has pulled right off the hull side.
Is it possible that the manufacturer or a PO used some kind of clear coat? I always thought gel coat was just gel coat and if it was removed you'd be into fiberglass. My understanding of the fiberglass construction, colors and gel coat is fuzzy at best, hopefully someone can school me.
That said, what do I do? I will be applying new decals eventually but I want this fixed. I do have some work to do on the keel and will be ordering some neutral gel coat along with a color match to repair the keel. Since the color is still good, could I use the neutral gel coat to go over this and gently sand and feather it in. I do have automotive grade sand paper already. Even though this portion will likely be covered up by the new decals, it will bother me if it doesn't get fixed
I appreciate any info and advice, you guys never let me down!
