Gearbox Reseal Questions
kevinwd1
I'm going through the process of resealing the gearbox on my 1962 28hp outboard and have a couple of questions .
1- Can I use Permatex Aviation Form-A-Gasket Sealant Liquid - No. 3 to seal the gearbox .I can only get 3M 847 in a large can at a cost of $65 .The Permatex comes in a small container at a price of $7
2-When replacing prop shaft seal and shift bush do you put gasket sealant on the outside of them to get a water tight seal?
3-Whats the best way to line up the pivot pin (before or after screwing gearbox together).Also what’s stops the pivot pin from leaking. Is there a rubber seal or washer that you replace?
4-Are the Sierra seal kits alright or should I buy genuine Omc parts
Regards Kevin
oldcatamount
Re: Gearbox Reseal Questions
Question #1; Permatex is fine
#2; can if you want to, not neccessary but it won't hurt to do it
#3; before it's put back together
#4: Sierra parts are ok
kevinwd1
Thanks oldcatamount
Regarding Q2 is a press fit enough to stop water entering gearbox as there is no actual seal on the outside of either parts?
F_R
I'd put some sealant on the OD of the seals. But not the SR bushing.
#3....If you have the upper gearcase upside down (you do have a "pickle fork", right?), and the gears & stuff in place, and in forward gear, you can go ahead and install the skeg and the pivot pin should be very close to being in alignment. That's how I do 'em.
Agree with post #4 ---nothing to it if done that way.
kevinwd1
Thanks guys ,will give it a dummy run and see how I go before putting sealant on.
boobie
3M 847 always came in a tube. Have you checked with a BRP Dlr to see if they make it in smaller quantities ??
F_R
Part number 7509A65 at McMaster-Carr for a 5 oz tube. $17.08. Enough to last a long, long time for most people.
..........iboats marketing dept---are you carrying this product? Maybe you should so we don't have to send your customers somewhere else.
boobie
Good point F_R...............................!!!
kevinwd1
Unfortunately postage to Australia makes a lot of things very expensive .Amazon was going to charge $25 to ship this product to me:mad:
kevinwd1
Saved by EBay again.5oz tube from the US cost $28 dollars delivered
