Gear oil type for a 1956 Johnson QD 17
John A Martin
I think the year is correct. It is a 10 hp with what looks like a long shaft extension piece. What is the oil/gasoline mix and what type of gear oil do I use? Thanks, John
EN2
Re: Gear oil type for a 1956 Johnson QD 17
I think these are 20 to 1.Gear oil 90 WT.
John A Martin
Thanks, the motor has been painted and it is hard to see what type of lower unit oil is recommended. It looks like it says:
Use VPD10 oil or VP010 oil. There might be a letter before the V.
50 to 1 oil gas mix is correct I assume?
John
John A Martin
O'oops, looks like you answered the question, 20 to 1 oil gas mix, and a 90 weight gear oil.
John
ezeke
The OE gear oil would be OMC/BRP Hi Vis, but any good marine high viscosity gear oil will work.
