SweeperForce
Thread starter- Joined
- Feb 7, 2010
- 487
Hello,
I have two questions
Today I tried to replace my lower unit gear oil. I removed th top two screws one said vent and the other said fill. The screws had what looked like a washer or gasket of some sort which was all chewed up. Should I replace them?
In order to drain the gear oil I loosened the pivot screw by accident. I didn't remove it all the way. I turned it back in snug. Then I put the motor in rear and tried to move the prop and the flywheel moved. Then I tightened it the rest of the way. So all is good right??
Thanks,
Tom
Thanks,
Tom
