gear case seals are leaking!
tommythecat
i was told i should start a new topic for this new problem so here goes. i changed the water pump and the gear oil in the lower unit and took it out for a test ride. it all seemed to work but when i checked the gear oil it turned white. i didn't go far and it was working well as i took it out so no damage im pretty sure of that. i don't know where the water got in but there was a bit of oil came out the weep hole right by the shift shaft so i was assuming maybe the shift shaft bushing? but how do i know and where all can it be getting water in?
so i also could use a hand finding this gear seal kit my boat motor model number is 857HE i think it is 1973 and it is a chrysler 85hp outboard if anyone can help i thank you in advance.
jerryjerry05
The weep hole is for anything that leaks down from the motor.
The shift shaft seal might be leaking? but the stuff you see might be unburned gas/oil?
It's easier if the drive is off and drained.
There is 8 different places that a 2 piece drive can leak.
I use a mix of Dawn soap and water sprayed on the seals when adding compressed air
You don't need a lot of pressure to make it leak.
10# or less should do it.
Do the test and post the results.
tommythecat
so i did the test today but i used 2 cycle oil and the pump for oil i had no air to use. it came back out the vent holes that water is supposed to go in! the little side screens below the water pump area. so i got the gear case seal kit here now im hoping this seal is one of the ones in the kit? fk1061 is the one i bought and its a oem not serra looks in good shape. so what's my next step? ps may have posted twice once in the 1rst forum i forgot i started this one also. i will stick here to finish it though, thanks for the help!
