I just purchased a 1985 Seaswirl boat with a Johnson GT150 outboard motor. The tach flips clear over to max when the key is turned on and the speedometer doesn't work. I think I can fix the speedo, but the tach is where my question is. Someone has rewired this boat and they have the three wires coming from the ignition console coming into it. They are purple, black, and grey. They have taken the black wire and spliced it with another wire that runs directly back to the negative terminal on the battery. Will this create a problem with the tack?
