gas tank vent
old jim
Open or closed when tied up at dock? Regars, old jim
5150abf
Re: gas tank vent
Open for sure, especially this time of year with the big temp swings, you want to at least leave it cracked so it can breath.
I am assuming this is a portable tank.
old jim
Re: gas tank vent
No, it is a built in tank on my Tracker. Regards, Jim
5150abf
Re: gas tank vent
Still open, as I said gas expands like crazy and you could cause all sorts of problems by shutting that off, that si why it is vented in the first place.
Silver Eagle
Master Chief Petty Officer
Re: gas tank vent
I don't understand this question. Why would you want to open up the vent? If you do your asking for trouble .Your light ends will cause vapors to come out of the vent .This could be a good source of ignition.Gasoiline can flash at 93 degrees with no source of flame. Plus you'll pick up ant moisture in the air which will get back into the gas tank.
MH Hawker
Re: gas tank vent
boat tanks must always be vented open. On the portable 6 gal tanks to closing the vent will turn them into footballs and may cause them to rupture, and if you forget to open it when running it will collapse the tank and it may cause fuel pump damage.
Ike-110722
Re: gas tank vent
Unless this is a brand new boat, a permanently installed fuel tank vent is always open. Prior to this year I have never seen a vent with a valve to shut off the vent. New boats that meet the EPA regs that went into effect on Jan 1, 2012 have a charcoal filter and built in p-trap, and automatic valves that close the vent system when the engine is not being run. But it is all automatic. But prior to Jan 1, 2012 the technology required that the vent be open. The point is to never have pressure in the fuel system. If the fuel system is pressurized, even as little as 1 psi, and you get a leak anywhere in the system, it will drain the entire contents of the tank into the bilge. Not a good thing. Even the new systems have a means of bleeding any pressure in the fuel system, but they do it without venting fuel vapors. Those are absorbed by the Charcoal filter.
Lawnmedic
Re: gas tank vent
The flash point of gasoline(the temp gasoline vapors will ignite from a flame is -45 degrees F. The auto ignition temp of gasoline(temp that the vapors will self ignite) is 495 degrees F.
The vents on portable gas tanks were designed to only be closed when moving the tank, so to not splash gas on you.
Cheetah 210es
Re: gas tank vent
If there's gas in the tank the vent should be open to allow vapour expansion and contaction.
