gas tank problems, water, vent
motorboater17
I have a poly tank under the floor of a 17 ft Pro Sport CC. Had water in it, thought I got it out, tried a 6 gal old school tank, ran great. Put 30 gals. in it, drove to the beach, tank had sucked down and gas coming out, HELP
Re: gas tank problems, water, vent
What do you mean by "tank sucked down and gas coming out"? Has the tank imploded and gas has leaked into the bilge??
motorboater17
the top side of the tank around the sending unit collapsed about 3 inches. Was pushing gas out thru the screw holes, I removed the unit, I could pull the top of the tank up, stopping the gas, let it go it went down and gas poured. Ran 5 gal out thru the bilge. Makes me think the vent is stopped up
motorboater17
it all started with water in the tank, pumped it out, changed filter, seperator, took a 6 gal tank to the lake and it ran fine, then I filled it up, this happened. Cant find a vent, unless the cap is the vent.
For sure the vent is blocked. Must be there somewhere - is this the first time you've run this boat?
Maybe someone else on the forum is familiar with this boat?
motorboater17
Pro Sport 17 ft center console, 30 gal tank under the floor, been running it for 3 yrs
So if it was working ok before draining the water from the tank, something must have been changed during that process. How did the water get in the tank? How did you drain it? When you hooked up the 6 gal tank you must have removed fuel hoses - have they been replaced correctly?
motorboater17
its all hooked up right, i took it loose from the in line filter, hooked that to the 6 gal tank. I think the sending unit wasnt tight, thats how the water got in, that and ethanol. I think now it has water in the carbs and I really wonder about the vent, what research i have done says it will run but not take gas if it is clogged. Also why did the tank sink when full, it should have vented out. Headed back down today and try to figure it out
UncleWillie
Your vent is plugged. It makes a favorite mud wasp home! :(
A 30 gallon, under floor tank will NOT be vented through the cap.
That would form a 30 gallon Molotov Cocktail.
The Vent fumes would settle in the bilge! :eek:
Find the Vent line, it goes through the hull, and clear it out. :D
Removing 1 gallon of fuel from a 30 gallon tank that has 6 gallons in it makes the air expand by <5% (0.5 psi)
Removing 1 gallon of fuel from a 30 gallon tank that has 29 gallons in it, makes the air expand by 100%. (7 psi)
The full tank will crush. the 20% tank will take it! :cool:
PWH1
I believe that is a "Deck Fuel Fill with Vent " fitting and not a tank gas cap.
An under floor tank will NOT be vented through the cap.
Hmmmm.... I have a 18 gallon under deck tank that is vented exactly in that manner - combination gas fill/vent.
OP - start at the tank and trace the vent line... You should be able to quickly discern whether or not its venting to the fill cap or through a hull vent.
joewithaboat
My 30 gallon tank is under the floor and vented with a cap exactly like the one pictured above. Vent line attached just above fill hose.
Combo cap/vent.
I agree that the vent is plugged!
It appears to me that there is some confusion in the replies as to whether it is actually venting under the deck, or not. It doesn't matter if there is a separate vent line from the tank, or from the vent cap pictured above, there HAS to be a line that goes to a thru- hull fitting. It can't just vent into the bilge!
bruceb58
They have the exact same thing that is a cap.
joewithaboat
No confusion here. My cap, like the one above, is mounted on the outside of the transom. "Thru Hull" has a fill tube and a separate vent tube both coming to the same fitting... vent/cap combo.
UncleWillie
Maybe this is getting lost in the interpretation. (English is just so much fun!) :facepalm:
An under Deck Tank may be Vented Through the Tank Fitting.
But it should not be Vented AT the Tank Fitting.
The vent fumes should not be allowed to accumulate into a closed bilge.
The vent line from the Tank Fitting needs to go through the hull and overboard.
Certain OB boats with open slat flooring and an open bilge in the rear that have no enclosed areas are exempt.
A portable tank sitting on the floor that vents through the fuel tank cap directly to the air is acceptable in this case.
But this is NOT the case with the OP's boat.
It has a fully closed floor with storage below!
If you have a boat with an underfloor fuel tank that you fill at the floor fitting, and is vented at the floor fitting into the boat...
You should spell BOAT, B.O.M.B. :eek:
bruceb58
Where do you possibly read that there is a fuel floor fitting here? Not even going to take into account that I have never seen a floor fitting in a gasoline powered boat.
So Willie, you didn't know that there is a combo/cap available. Why are you complicating matters here?
UncleWillie
I am well aware that both Fuel Tank Gas caps and Thru Hull Fuel Fittings are available with integral Vents. :)
If the tank is in the floor, and the tank is stated to have a "Combo Vent/Cap" and not a "Thru Hull/Deck Fuel Fitting," where would one assume the Vented Cap would be other than at the floor? :confused:
I suspect we are all actually in agreement and the problem is in the nomenclature. :D
When I hear the words "Fuel Tank Gas Cap" I envision a gas cap on the fuel tank.
I do not picture a "Gas Cap" on the side of the boat.
The "Combo Vent/Cap" is refered by the manufacturer as a "Deck Fuel Fill with Vent " and not a "Gas Cap."
