buckstop108
Thread starter- Joined
- Aug 2, 2007
- 67
:redface:I need to change the fuel lines/hoses to my outboard. When I looked to get the size off the hose one section was 5/16 motor side of the primer ball and on the tank side it was 3/8 . What is the correct size for a 1992 Evinrude 85 hp outboard tiller with oil injection? If I go with the 3/8 do I need to be concerned with what that does to the oil mixture? I imagine it was all calibrated at the factory with how much fuel goes through the line. While changing the hoses I was going to add a water seperator as well. This would go onto the tank side of the primer ball correct?
