Not sure which forum to use, just in case the motor is a Suzuki DF140, 2006
When the temperature if VERY hot (over 95), I sometimes lose priming after sitting with the motor off for a few minutes. What happens is the motor will turn on normally and I get about 50 yards before the motor dies. At this time the fuel bulb is soft, and I can usually get it running again after a few pumps. Without pumping the bulb the engine doesn't start.
This issue started 3 years ago, and I had the anti-siphon valve replaced. I didn't happen again until this year, but it has not been as hot in the meantime.
Any ideas? Thanks in advance.
