Kevin J. Kenney
Thread starter- Joined
- Jul 31, 2006
- 1
having problems when I start running at mid-speed after
minute into speed the engine slows and then shuts off.
It will start back up. sometimes it is ready to shut off and
I will take it out of gear and it would idle. Had problems
with water early in the year, but I replace the tank and
ran okay for two trips. I had the boat in the water started
up okay and then it stall. Tried to start it would turn over
but would run , checked gas screen out ok, dropped bowl
little gas, and adjusted ible screw. Crank without choke
finally started and then I started having the problem.
