Gamefisher Model 225587504 5 hp serial#8869
Vintin
From what I've read here this motor was made my Merc.
I've owned this motor a short while and have never had it running for more than 10 seconds or so. It looks like it has seen little or no use.
It's difficult to get it started in a barrel and when it does start it only runs for a few seconds then dies. Seems to have good spark.
I've had the carb apart and it looks real clean. I've air blown out the small passageways and re-sembled......still acts the same way.
I would like to get a service manual for this motor if it's available.
Thanks for any help.
Del
Vintin
Re: Gamefisher Model 225587504 5 hp water cooled
Just wanted to add that I've got the parts diagram from Sears and this motor has a tillotson #71206 carb.
79Merc80
Mercury marine did build it, but I'll bet it's a Force engine. Do you have any pictures?? and/or a serial #?
Vintin
The serial number is 8869.
Thanks.
Vintin
They were all built by Force per the attached:
http://www.discount-marine-parts.com/ob_elgin_force_model.html
225.587504 0E018529 & Below 1991 5 1
225.587504 0E018530 & Up 1992 5 1
225.587504 1993 5 1
See note in red at top of the page:
(All Models Built by Force)
Gerry
Thanks for the info Gerry. I was hoping it was made by Merc!
Any idea where I could find a service manual?
I think there may be a problem with the float valve as when I pump the fuel tank bulb the bulb does not get hard......just keeps on pumping.
