pcrussell50
Thread starter- Joined
- Sep 21, 2008
- 296
i read on here shortly after i joined from some guys who said that stainless bolts will dissimilar metals-corrode more aggressively than stainless ones, in the the aluminum of outboards. i had a hard time believing this when i first read it. but i sure had a tough time removing the lower unit of my big twin '59 super seahorse 35hp, rds-21b. thankfully, i didn't snap any bolts off, [whew!!!]. i ran this topic by my extremely engineer-rich sports car racing forum, and they agreed with you guys. they posted a link to a very informative chart of galvanic potentials, which also mentioned that in extreme environments like salt water, stainless and aluminum are simply too far apart, [too much galvanic potential], and that mild or ordinary carbon steels are not.
so, on the surface it looks like i ought to use grade 8's in place of all those stainless screws and bolts that johnson already had. the screw heads are all munged up anyway, so they will need to be replaced. i use this engine in salt water, but i never store it in salt water. i use it and clean and flush with fresh each time. sooo, it is worth relying on the "science" and using carbon steel bolts, with lots of non-copper anti-seize? the only concern i have is that i think johnson used stainless bolts... then again, maybe they didn't and the stainless stuff was put there by the previous owner/maintainer?
so, think i can get away with non-stainless bolts with anti-seize? [as long as i don't keep the boat in salt water?
-peter
-peter
