stockdragrace
Thread starter- Joined
- Mar 12, 2006
- 22
Gentlemen, I have purchased the correct 5 pin cable from control unit to tach that I am trying to install, I checked, and I have good 12v power and ground to the harness, but how do I check to see if I am getting a signal on the grey wire which is the one that is supposed to be sending the signal to the tach? I bought a used tach that came off a new boat, and have tried to set the switch on the back of the tach in all positions ie. 6p etc., but still get no readings at all on the tach, other than it goes to zero when the ignition switch is turned on? Not sure if I have a bad/incompatible tach or just not getting a signal from the engine.Your help as in the past will be greatly appreciated. Thanks, Brad
