ziggy
Thread starter- Joined
- Jun 30, 2004
- 7,473
i recently had to replace my port hardtop window. the reason i broke it was because i had the hardtop slid back and was going fast in rough water. like in rattling my fillings out of my teeth. anyways, the port window popped out of the top. some of the window to the outside. their made to come out the inside. anyways, i couldn't flex the window enough to get it back inside the boat. in the end i broke off a piece of the window trying to get it back in position. then it was able to be removed after i broke the piece off.. :facepalm: fwiw, i had been told by AristoCraft a long time ago that the hardtop wasn't designed to be slid back and the boat operated in harsh seas. the top racks to much. i'm a believer. i feel the top racking was the cause of my window popping out of it's mount.
anyways. ArisotCraft still has windows available for the nineteen (way cool and unprecedented for a boat 36 years old). picked me up some. they are only sold in pairs. which is fine since 36 year old plexiglas will have wear to it. having 2 new keeps them looking the same. however ya gotta cut to fit. which i didn't understand at first.
above are the pics. the old window on top of the new one. ya can see the need for cutting to fit.
i used the original window as a template. i masking taped the new window so i could draw some lines on it. then traced. prior to cutting i took them out to the boat and confirmed where i wanted to cut. i cut on the lean side (too big, need to take more off) due to only getting one chance at cutting. this worked fine, just more time consuming than it should have been.
AristoCraft said they use a belt type sander to trim the windows to fit. or a band saw perhaps. well, i had neither tools. so i used a sabre saw. medium blade, 12 or 13 teeth per inch. slow to medium speed. this worked very well. i just stabilized the window on a table top on top of an old tshirt.
both windows are now in place. looks like nothing ever happened. perfect. Kudos to AristoCraft for continued support of their very excellent boats. Thanks for your help Bill.
ps, i guess the tabs ya see on the new window is the way the window is held in place during the making of the bubble part of the window. designed to be removed prior to install..
