sam am I
- Jun 26, 2013
- 2,169
I haven't watched the video (yet) BUT!! I have an idea as a work around for your dead 12/24V relay feed!
So if the low side (dynamic PWM/neg toggling side) is still working (cross fingers) then lets just make our own 12/24V high side!!
Just remove the motor's red feed wire (switched 12/24V) off the controller board and tie it directly to 12/24V....Hit the pedal!!
Like I said, if the PWM low side is still PWM'ing, she'll spin up as normal....
So sticking with the original intent of the design...(I think they turn off the motor's 12/24V feed with the relay as a safety thing. In the event of a PWM failure that shorts to ground, the motor would be stuck in full out freaking s**t the bed run mode and you could crash and burn)
If that above test works, crack open the relay from the top side (surgeon style), fish out (add extension wire too) the relay's coil + feed wire that is still making the relay click and we'll add your own 100% functional external relay(use the 12/24V we made as a test plus the coil + and ground) and WE STUCK IT TO THE MAN!! Love being cheap too!! That's probably the best part.
