Fuel vent question
maineiac5586
Master Chief Petty Officer
1997 wellcraft 190ccf center console.
I was inspecting the fuel tank vent and have a question. 5/8 vent hose going to a thru hull vent. I have trouble filling the tank all the way. It goes from nothing to expulsion of fuel very quickly. I unscrewed the vent cap and looked in and saw the picture below. Does that look correct? If I need to replace it what is the best vent I can get? Thanks
Ayuh,..... Never seen a fuel tank vent that looks like that,.....
All the ones I've seen are a cast 90* elbow through the hull,.....
The vent line, should go from the fitting, Up into a loop, 'n then drop into the tank, falling all the way,....
maineiac5586
The vent line is fine just concerned with the vent itself
MikeSchinlaub
I agree with Bondo. That doesn't look like a proper fuel vent. A fuel vent should be as he described, an elbow with the opening facing down and a fine screen in the hole.
That looks like some kind of one way valve intake or output. If that's what your vent line is hooked up to, it's likely the problem.
dingbat
Blow compressed air back through the vent. Quite possible the vent is water logged
Run into several boats over the years that were slow to fill because of the orientation of the fill and vent.
Boat would take fuel w/o incidence on the trailer, yet kept kicking out on the water
maineiac5586
I'm mostly concerned with the appearance of the valve inside the hole. What's up with the little hole? Is that supposed to be like that?
MikeSchinlaub
This is what your fuel vent should look like. There shouldn't be any valves in it. There are other styles, and newer gas fills have the vent as part of them.
Gee, your fuel tank looks to be made of fiberglass. If so, the alcohol in today's gasoline can dissolve some of it's components possibly causing leaks.
I agree that the tank vent looks unusual.
As for your filling issues. You normally want the vent fitting on the tank to be as far forward as possible. That allows the minimal amount of splash of fuel out the vent.
MikeSchinlaub
It could be plastic glassed to the boat. I saw one like that once. I think it was the Skeeter I did the floor and stringers in.
maineiac5586
Turns out that little black speck in my vent tube was a tiny piece of plastic. I removed the vent and will be installing a flush mount vent with elbow along with new filler hose. New vent hose and new fuel feed hose. Crazy how expensive hose is these days but will give good piece of mind. Thanks for all the help.
