76SeaRay
- Aug 24, 2017
- 1,071
I am not home right now otherwise I would take a picture. After setting the tank in place to squish the peanut butter out, I found that the front corners actually sit down directly on the hull. The slope was such that the front strips of neoprene were about an inch in too far to pad under the corners. I think the best thing to do is to get all four corners set on "footings" that keep the outside edges of the tank from resting directly on the hull then run a straight edge front to back to set the level of the other pad footings.
