Fuel Tank problems
pikerpiker
I can't get any fuel from my built in fuel tank 20 gal plastic . I tried another portable tank and my outboard mercury 75 hp. ran great? I tried putting another fuel line on to the built in tank and no fuel and no pressure in the fuel line.I have about 9 gallons in the tank now and the boat is sitting level. I took out the pick up tube and ran water thur it and water ran thur fine? The screen is not clogged. I unscrewed the gas cap to see if it was the vent but nothing? Any help would be great . Thanks Chris
LongLine
Re: Fuel Tank problems
Is the anti-siphon valve/ball stuck?
Tom B.
(LongLine)
pikerpiker
I don't have a anti-siphon valve on this set up .Could it be something else?
NYBo
Did the new fuel line you tried include a new primer bulb?
EddiePetty
...which way ya' got the primer bulb pointing?????
pikerpiker
Yes the primer ball was new and the arrow on the new fuel line was pointing toward the engine.
Beefer
There is a vent somewhere, and it's probably clogged. Find it and check and clean as necessary. Not sure if this would work to determine if it's a clogged vent, but have you tried to run it with the fuel cap off? If it runs with the cap off, then it's definitely the vent.
pmillar
If it's a venting issue a motor will usually start ok (if it's been sitting a while) then die as the vacuum builds in the tank leading to fuel starvation as the fuel pump has to work to overcome the vacuum. (sorry for the run-on sentence.)
As mentioned above, if it works with the fuel cap off it would be a venting problem. Another hint on venting problems is a whoosh of air into the tank when you remove the cap. That indicates a vacuum has built in the tank as fuel is pumped out but not replaced by air.
