Fuel tank float
Vertigo
How do you check if your fuel tank float is working properly? I have a 1987 Thundercraft (Canada) Starflite and it has an built in fuel tank. How do you change the fuel tank float?
Re: Fuel tank float
You change the sender as an assembly. You use an ohm meter to verify operation of the sender. 240 ohms empty, 109 ohms about 1/2 full and 33 ohms full.
Vertigo
Re: Fuel tank float
Great, but where do I find it on the boat?
