Original fx
- Sep 11, 2010
- 3
Hey guys I just started with Iboats forum and I have a question. I have a 79 Johnson 100hp on a 88 bayliner 17' with builtin tank. I had problems last year as well. I made a winter project out of the boat. completly flushed the tank. Now with new floor and everything new I still get a loss at full throttle after a few minutes. I have in this order Tank, inline glass filter, fuel/water seperator, bulb to motor. Idle is good and very low speed is good. I checked the fuel pump and found damage. Installed a new one today. Took the boat out and still have the same issue. I took an a portable with me and after the problem I hooked it up and the motor ran fine at full throttle. I am using an attwood fuel/water seperator and johnson oem bulb and hose 5/16. The tank only has a barb fitting not a antisyphon valve. The vent line is completly clear. The service manual says to keep the tank to the fuel pump under 24" and mine is about 21". What am I missing? I would appreciate any help. I don't want to just use my built in tank for a fuel storage. Thanks.
