familyguy
Thread starter- Joined
- May 30, 2008
- 69
I have a 19 gal. Moeller Marine crosslink polyethylene tank and have noticed a strong fuel smell everytime I take the cover off or put my nose in a storage hold or the engine compartment even when the cover has been off for some time. Sometimes when I'm out on the water I will smell it fairly powerfully, too. I know fuel vapors sink. However, if I've had the cover off for some time shouldn't the vapors dissipate?
Looking at a moeller's marine gas tank weblink I read something about "permeation" and that this is normal. Should I smell gas around the tank because the gas has saturated the tank wall material and this is normal? The boat does a engine compartment blower.
What I've done so far:
1) Exposed the tank
2) Plugged the fuel pump supply hose, plugged the fuel fill hose, and applied vacum pressure to the vent line. I'm unable to register any vacum pressure.
3) Then put positive pressure with my lungs into the vent hose. Was able to see the tank start to bulge. Took my mouth away and audibly heard pressured airflow leave said hose.
I don't have a positive pressure gauge that reads small increments of psi. I know I can get one fairly cheap, but how do I apply a small amount of positive pressure to the system once it is attached (without blowing into the system with my mouth), since I don't want to exceed 3 psi? I'm trying to pressure test the boat side of the fuel system without having to drain the tank and pull it.
1) Exposed the tank
