fuel shut off valves?
fordmugg
i want to install 2 shut off valves in my boat, one for each tank, now do i need special ones of can i just get some ball valves from like home depot
Re: fuel shut off valves?
Ayuh,.... Most of Us just use a 3-way tank control valve.... it's made for Gasoline...
fordmugg
doesnt the 3 way only have 1 tank 2nd tank or off? what if i want to run both tanks for a while then finish 1 tank and have a half tank back up
Ayuh,... If the fuel pump, pumps from Both tanks, it'll suck air, not gas...
That's Why ya use a 3-way valve....
Run a tank to empty, or nearly so, 'n Switch 'em....
Yer motor won't run suckin' fumes from an empty tank.... ;)
fordmugg
my 20 ft hallett has dual 22 gal tanks so if one is empty and one is full, will the offset weight make a difference?
achris
More fish than mountain goat
22 gals weighs about 60kg (130lbs). If it causes some listing, just move some gear to the other side (Use the drivers side tank first)... Even with both valves open, it wouldn't suck evenly from both sides, it would empty one tank first (path of least resistance)...
jayhanig
Master Chief Petty Officer
Run off tank 1 enough to burn off 10-11 gallons, then switch to the second tank for the rest of your trip. You''ll end up with half a tank backup with minimal listing for the majority of your ride.
fordmugg
Thanks for the info guys
agallant80
I am wondering now if this would be good for putting the boat up for the season. Run the motor out of gas so none is sitting in the carb on in the fuel injectors.
smokeonthewater
the recommended storage method is EITHER tanks nearly empty and fuel chemically stabilized OR tanks full and fuel chemically stabilized either way is fine but half a tank is the worst possible condition... Engine needs to be run long enough to ensure that stabilized fuel is throughout the entire fuel system
