Fuel sending unit
lynnboy021
Anyone knows the ohms to test if it's good or not??? Fuel gauge is new but gauge is not moving...
sam am I
Re: Fuel sending unit
Marine type sender typically 240-33Ω empty to full respectively
tazrig
But there are also several other ratings for the senders. You need to have a gauge AND sending unit with the same ohms ratings or it won't work.
lynnboy021
well when I got the boat none of the gauge worked good and the fuel did not wok at all so I just replaced all the gauges.......
tazrig
The kit that those Faria gauges came in should tell you what the ohms rating for the fuel gauge is or just call where you got them from. Then check the fuel sender at the tank. Remove it test it with an ohm meter to see the range.
