fuel pumps
circle hook
does the I Boat store carry older fuel pumps that what is on the site I need one for a 1964 18HP Evinrude Serial# 18402D I looked it up on their boat store but can't seem to match mine up with anything they list. again Thanks Bob
circle hook
Re: fuel pumps
Tashasdaddy is it the one part# 18-7350 it dosen't say 18HP only up to 15HP, But the gasket between the block and punp kind of looks the same, do you think I should go with it.
F_R
Re: fuel pumps
The mounting bolt pattern is the same on all motors. The differences lie in the direction that the hose fitting points. If the hoses can be re-routed to clear any obstructions, it will work just fine. The "big" inlet hose fitting can be re-positioned in any of four positions. Note that you are not supposed to mount the pump upside down because it could air-lock.
The 18-7351 is another option, usually more forgiving of hose direction.
Re: fuel pumps
Circle, Can you not get a rebuild kit for the original?
circle hook
Re: fuel pumps
No that's not the problen, one of the plastic barb fittings that is molded to the pumps body is completey snaped off, so I just bought a new one from I Boats web store. Thanks Bob
