fuel pump
jasonmmoore
i have a mercury 50, when i squeeze the primer bulb fuel leaks around one of the fuel pumps, could this cause hard starting and NO top end and can it be rebuilt??
usskydvr
Re: fuel pump
What year? If the fuel pump leaks when you pump the bulb, then it probably sucks air when not under pressure which would cause lack of WOT RPM. Sounds like it is time for them to be rebuilt.
jasonmmoore
Re: fuel pump
i dont know the year but it is on a 1991 bayliner the engine serial number is A158656, i bought a kit and replaced all the gaskets and diapram in the pump but it still leaked when i squeezed the primer just barely though. i tightened the screw in the middle of the plastic piece where the hose connects (which is where it was leaking) do these things get cracks in them or something? also cleaned fuel filter the tank and bulb, line is also new.thanks for replying
usskydvr
Re: fuel pump
Does the fuel pump look like the attached?
Is your motor a 3/4 cyl 2/4 stroke?
jasonmmoore
Re: fuel pump
it is a four cylinder, 2 stroke the year is 1985 fifty horse. the fuel pump does not look like that, it has one on the side of each carb took it out again today same thing happened
usskydvr
Re: fuel pump
You must have one of the WMK series carbs. See pic. There are several gasket kits for these and you need to make sure you have the correct one. Also the Strainer covers do crack easily when he motors get older and you are messing around with the fuel lines. Check this site. http://www.maxrules.com/fixmercurycarbkits2.html#13959023
