Fuel pump whine only after filter change
AdamIPS
I changed the fuel filter today on my 8.1 Gi-H. After doing so, the pump now has a lot of whine which it wasn't doing before. I assume the system is self-priming after changing?
I cycled the key many times to see if it was just air. At idle, it's also surging a bit. I switched filters again and that didn't help.
Previously there was a Sierra filter, but I swapped to Volvo #3847644.
Any ideas? I'm hoping the fuel pump isn't about to tank.
89retta
Did you fill the new filter with some gas prior to installing ? Sounds like you have air trapped in the pump
AdamIPS
Yes, it was filled. Thinking there was possibly a blockage, i swapped another filter in. Same situation.
