Re: fuel pump question...
The rules posted above said, if you have a new question. Start a new thread. My original question was regarding to the compatibility of a new block with existing heads. New question was about whether or not I'll need a new fuel pump to rebuild the motor.
sorry if I broke the rules.
Ayuh,... It's All about yer motor swap, 'n the issues yer gonna see...
If you post a thread for each issue,...
Nobody'll know what yer talking about...
If you run a thread about the Swap Job, you only have to post the pertinent info once, instead of in each thread, 'n it saves a ton of Confusion on everybody's part...
The block swap is what perceptated the fuel pump issue...
Mechanical fuel pump, but don't the vortec engines have an electrical fuel pump? If so; is there a mouthing location for a mechanical fuel pump on a block
Merc mounts the fuel pump, 'n fuel filter right down on the block near the same place as the mechanical, on a bracket..
